Productos
Old software
Contribuir
Traductor voluntario
Probadores beta
Empresa
Zona de revendedores
zona de afiliados
Servicio B2B
Sobre nosotros
Ayuda
Productos
Contribuir
Empresa
Sobre nosotros
Ayuda
< Devolver
Todos los productos
Old software
< Devolver
Probadores beta
< Devolver
zona de afiliados
Servicio B2B
< Devolver
Audio Stream
The selected audio is shown in blue and plays in the preview.
To listen to another track in the list, simply click on it and it will play and be highlighted in blue. You can remove an audio track by clicking on the red circle at the left of the track.
Clicking on
will open the
edit the stream
Audio volume filter
(NEW in Version 6)
Output format
- Automatic:
Converts audio to AC-3 format.
- AC-3, 5.1:
Converts audio source stream to AC-3, 5.1 channels even if source contains less or more than 6 channels. When selected, it'll be matrixed and down/up mixed to the 6 channels.
- AC-3, 2.0:
Converts audio source stream to AC-3, 2 channels. When selected, it'll be matrixed and down/up mixed to the 2 channels.
- MPEG:
Converts audio source stream to MPEG format, with an output of 1 or 2 channels. If necessary it will be down mixed (for ConvertXtoDVD only)
Clicking on
"show advanced"
will reveal even more options:
Offset
Menu text
is the text that will show in the menu (if you've selected one). You can edit it with your own text.
Language identifier
is a tag the stream will be associated with. The language identifier will be a language abbreviation such as EN, FR, ES . . .
It does not appear in a menu or on the DVD but identifies the stream to a DVD player - this language identifier can be seen when you press the audio button to activate of deactivate audio on a remote control and it will display the tag of the current stream being displayed. ConvertX tries to automatically detect the language of the file but if no information is found "? Unspecified" will be displayed. If the detection is not accurate, you can change it. If it is not detected you will see "? Unspecified". Changing the Language identifier will also update the language in the menu text above. You can however customize the Menu text - edit it after having select the correct language identifier. Don't know what language is the right one? Play the video in the preview window listen to the audio and then select the corresponding language to what you just heard.
Select "
Set as default for playback
" if you have more than one audio to convert and you want this one to play by default when you play the disk.
Go to Subtitle stream tab
Go back to Main guide
